Noctua nh-d14/c14, True spirit 140, Silver Arrow, Cm tpc new cooler...
The Noctua NH-C14 doesn't belong there. It can't even handle my Bloomfield at 4.0 with The Beast installed, much less the stock fans. And can't handle 3.8 except with high speed fans. Review coming soon.
Getting a max oc out of a Bloomfield is nuts if you run 4.0 Ghz 24/7. They run hot.
150 watt load is the norm, 200 watts isn't. 200 watts for a single benchmark run, yeah. Not a 24/7 oc @ 200 watt load. You sound like a juvenille braggart advocating yourself over Frosty tech, they've been around and have followers for a decade.
I am grateful to muddy for pointing out just why the frostytech reports of heatsink performance differed so much from reviews on the rest of the web. Generally one will find broad agreement on the performance of heatsinks. Sure, they may differ by a couple or even a few degrees, but frostytech seems to inhabit another universe. Now I know why.
And here I thought they were just showcasing heatsinks they made a higher profit from. Silly cynical me.
As for my own test system, it's an i7 860 running at 4GHz on 1.32v. I think there's more happening on the cpu silicon of the 8xx's than the 9xx's because the northbridge is part of the cpu. So it gets very hot. Amps? <shrug> Dunno. Guess I'll have to figure that out. Haven't cared because I've been about comparing fans on the same heatsink, not comparing heatsinks.
That said, The D14 and the Megahalems can cool equally well on my rig, but the Megahalems needs a stronger (louder) fan. It makes sense, when you consider comparative square mm.
Muddy, you know TRUE's. Do they have more plates, closer together than the Mega? Seems that Trues benefit more from stronger airflow that other heatsinks, which tend to level out.
