Actually if you look at the tests monsta's tend to fall off snip ............[/url]
If you look at push/pull low rpm tests then the monstas come into play.
With thin rads - push/pull low rpm does not give a great benefit however with the thick monsta rads push/pull setups really help out due to the thickness of the rads.
Also note that monsta rads have very low fin density (approx 9 to 10 FPI) so high rpm airflow is not their forte.
I already posted these results in this thread and have also pointed out the price premium vs performance am unsure if Waza has taken a look at them.
No one seem to have any idea about the performance of the EK-CoolStream CE 280mm which is what I am comparing the UT60 280mm to not the monsta!
Their are numerous test results out their with the monsta and UT but very little with regards to the EK-CoolStream CE 280mm I posted in the hope that the many forum members here somoene would be able to shed some light on this.
So across the two English speaking premium forums with regards to watercooling on the Internets no one seems to be able to post any info regards the comparative performance of the EK-CoolStream CE 280mm against the UT60.
Looks like I am going to do a Google translate and goto the French and German speaking forums !
Hopefully someone will step forward and talk about the EK-CoolStream CE 280mm rather than the monsta
** EDIT **
With little information coming from the communities here is my conclusion.
I will be going with the EK-Coolstream CE 280mm based on the research I have done over the last day or so with comparative analysis of the data that is available that I think is important for my current WC setup
Radiator | FPI | Tube Count
UT60 360mm | 10 | 12
EK XE 360mm | 15 | 14
UT60 280mm | 10 | 12*
EK CE 280mm | 16 | 14**
If we compare directly the UT60 360mm against the EK XE 360mm then the EK XE 360mm comes on top in almost everything performance related.
As long as your pump has good pressure, then the rad with more restriction has no tangible effect. The increased restriction of the EK rads is because they have more tubes.
* I couldnt find statistical data for the number of tubes the UT 280mm has but due to the fact that it is 60mm thickness and that the other Alphacool radiators are all low restriction i.e. less tubes I would guess that the tube count is the same as its other brothers i.e 12
** Again couldnt find statistical data for the number of tubes for the EK CE 280mm but again, considering that it is 45mm and its other brothers i.e. CE range have tube count greater than 14 I used that as the minimum value.
So based on the above, I believe that the EK CE 280mm will outperform the UT60 280mm because
1/ It has a higher FPI to counteract the loss of 15mm thickness
2/ It has more tubes to dissapate the heat through the fins to counteract the loss of 15mm thickness
3/ The EK XE 280mm easily outperforms the UT60 280mm
Ofcourse this is all based on the two assumptions made above i.e. * & ** and my evaluation of statistical data.
Hope this info is helpful to other!
