Kuroimaho said:
Probably the side effect of seeing pics of a 3G K10.
you are a moron, period.
When you people stop thinking of time as an IMPLICIT factor, then you will understand TIME as a machine sees it. it is not but an extension of Elemental Reality. And this Dimmensional reality becomes Irrational, in order for our feeble brains to understand it, we take shortcuts in R^2. Newton took shortcuts and assumptions @ R^2, when explaining his laws. And truthful as his laws maybe, this is where calculus and derivatives are born.
He took the work Left to be Done by Descartes in the 1600´s, and manipulated it to conform his own understanding of Vectors at R^2. but he never resolved the problem of irrationality left by the understanding of what happens at a certain point in time.
You can also see it through the simple eyes of Euclidean Geometry.
Degrees are not but an
approximation of time. So when programmers understand Binary Better, And how information is Restructured under different Ranges(dimmensions) of a Matrix. then and only then you will know what i am talking about.
A Tangent Line, is that which explains what happens at a certain point Through the
work done By a Function, it explains the curvature generated by x^2. or in Einstein´s equation of E=M * (C^2)
In the AMD case the curvature is generated through time, and this evidence is irrefutable through out mathematical history, and analyses.
When taking the Square root of x^2 you end up with 2 answers, X1 and X2, a - or +, a Truth and a False.
If both answers Exist in the body of Rational Number, The matrix will have an inverse. not only that, you can find the proportion of a/b and these will be at the most, whole numbers or coprime(no irrationality here).
But if the Root of the Quadratic or Square numbers are Undecipherable on either side(X1, X2), then the matrix will not have an inverse, and you have an Irrational Expression in the form of Imaginary numbers, non re-normalizable.
example:
X1/X2=a/b=1/Infinitesimal Irrational Number= Indeterminability IF 0<b<1
or
Infinitesimal Irrational Number/1= is ever increasing= Indeterminability. IF a 0<a<1
Important to be able to understand that Irrational Infinitesimal Numbers follow this law,
0<X<1.
I am not a programmer....
However, Math considers Irrational numbers to be Part of the BODY of Real Numbers. So when structuring your system you have to consider conformity in different Infinitesimal levels. X * 10^n. the Scalar Product of Exponential Numbers.
So lets review Sequencing.
Sequencing-
Sequences ASSUMES the Existence of Natural Numbers(part of the body, and beginning of, Q, Rational numbers).
Out of combining the Assumptive Existence of these Natural Numbers, with Rational Numbers, Infinitesimal Numbers are born, and So are Irrational Numbers.
This is not theory, this is called Algebra and if you don´t know how it works, then you dont know binary, and im wasting my time with you people.
you must review Sequencing in order to understand AMD´s Train of though.
A Sequence will determine the Vector component of a matrix along the Row´s or Columns, and Thus Virtualization Mapping is achieved.
The map is Given by taking the Co-Factors and Determinants(excuse my lame translation).
A LI set of Generators can compose LD Generators, and both of these can tpye of generators can compose, Linear Combination Generators of these.
These are the Vectors of a Binary Matrix.
(if you dont know what im talking about you must study Vector Spaces).
so must i go on?
Havent you people ever Studied Gauss?
cause it seems i´m teaching you people how to read binary.....
