For those who use the Thermalright SK6 with the Delta 60mm fan (or those in the 'know'), have you replaced that Delta fan? If so with what?
That Delta screamer is really starting to drive me nuts, I have had my AMD XP system running for over a month now. But lately that constant whine is getting to me. I have just replaced the 3 stock fans in my Lian Li with Panaflo 80mm fans, I noticed an drop of 3 degrees in my temps immediately. I will be adding another fan, maybe 2 to the case. Another Panaflo 80mm and one stock ADDA 80mm to help compensate for replacing the Delta 60mm.
I'm looking for a good, reliable replacement. One with a low dba rating, the Delta is rated Speed: 6800 rpm, Air Flow: 37.61 CFM, Noise Level: 46.5 dBA Any suggestions? I think I will compensate somewhat for the loss of cfm with the much improved air flow of the case.
