Tyranos Member Joined Jul 20, 2001 Location OR Nov 7, 2002 #1 What do you guys think of this compound to act as a sealant for a pelt set up? Arctic says its an absolute electrical insulator.
Wicked Klown Hard *** Southern Boy Senior Joined Dec 20, 2000 Location Sheboygan, Wisconsin Nov 7, 2002 #2 Thats what I was using with my T-Bird. I was getting temp of 24C idle and 30C load. However this time around I'll be using AS2.
OP Tyranos Member Joined Jul 20, 2001 Location OR Nov 8, 2002 Thread Starter #3 so it's ok to pack the socket full of this stuff?
ManOfKnight Member Joined Jan 26, 2001 Location Back in Iowa :( Come on Gators, Get up and Go! Nov 8, 2002 #4 why wouldn't you just use foam? use this to make sure the foam makes contact...but use foam overall, air tight
ManOfKnight Member Joined Jan 26, 2001 Location Back in Iowa :( Come on Gators, Get up and Go! Nov 8, 2002 #5 don't forget to foam the backside of your MOBO also...this will help stop condensation forming there also
OP Tyranos Member Joined Jul 20, 2001 Location OR Nov 8, 2002 Thread Starter #6 What type of foam can I use, and where can I get it? (in walmart?. only place open right now ... )
C Colin Arctic Silver Senior Joined Dec 19, 2000 Nov 8, 2002 #7 Arctic Alumina is a thermal grease. Put some neoprene in the center of your ZIF socket and dielectric grease in the pin holes.
