- Feb 10, 2017
Here's the situation.
The system has been running stable for many months. I have been running a Ryzen 7 @ 3.8GHz / 3200 MHz memory (about 11% overclocked) with a stock cooler for the entire time with no issues. I started a backup to my USB drive and walked away. When I returned, the system was at the boot prompt indicating that it had rebooted due to a CPU overheat. I have been monitoring the system for a long time - it has never shown any indications of overheating even when gaming or fully stressed - certainly not while performing an unattended backup. This is the first time anything like this has occurred.
Since then, I cannot run Windows except in safe mode. I get a selection of blue screen events - often, IRQL_NOT_LESS_OR_EQUAL, but several others too. The system boots fine, I can log in, but within 2 minutes something fails and the system crashes. If I boot in safe mode, the system runs without error. So clearly it's a bad driver, right? I finally bit the bullet and decided just to reinstall windows since I was too limited in what I could accomplish in safe mode, but here's the rub. I cannot get the windows installer to run either. It boots, discovers my hard disks, but before I get to the installation phase, it hangs.
I have replaced the video card with a spare, removed my sound card, uplugged every USB device save keyboard and mouse. I have reset the BIOS to optimized defaults for now, with no overclocking and the memory bus running at 2133 MHz. Windows memory diagnostics pass without issue. I can run CPU-Z from safe mode and execute a CPU stress test, but this I expect isn't a very telling diagnostic. I have some reason to suspect it might be related to the USB chipset given some of the failure modes, but nothing concrete.
So I'm left thinking it's one of two things - something non-critical failed catastrophically on the motherboard (hence the unexpected overheat event) or Windows has made a recent kernel change, delivered through windows update and in the most recent online boot image that is not compatible in some way with my hardware. Either way, I'm kind of stuck - I can't run the system, I can't reinstall the system, and I don't really want to shotgun a motherboard and processor in search of the cause. Does anyone have any experience like this?
