ASUS emailed with some feedback on the review and has requested a few clarifications & inclusions. These have been incorporated into the article.
When mentioning the OC Panel in normal mode, this sentence was added:
Note the bottom buttons on the left and right - they implement an OC Profiles you set in the UEFI and adjust the CPU Fan Speed, respectively.
Added more detail re: VGA HotWire for those that may not know what that is:
For those of you that don't know what VGA Hotwire is, here is ASUS' description:
"Propreitary VGA hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages from ASUS ROG MBs on a hardware level."
On ASUS cards that feature VGA HotWire plugs, it's as simple as plugging in (or soldering, on some cards) six wires and then plugging them into the OC Panel for full voltage control via UEFI, in the OS and with the OC Panel.
When describing the LED indicators that flash as you go through post, I forgot to mention their name, which is QLED.
Re: Thunderbolt
* Clarification, courtesy ASUS - Thunderbolt is supported by the Z87 chipset, but it is not native, thus it does require an additional controller built into the board, which would come as an extra expense.
At the end of the UEFI section:
Author's note: I forgot to mention two features of the UEFI. One has to do with the SATA configuration - You can rename the ports in the UEFI. Additionally, and an important thing that I just forgot is "My Favorites". You can add commands to this menu (hit F4 while they're selected) to have all the settings you want right there for easier access.
With regard to TPU in AISuite III:
Author's Note: ASUS pointed out two items I forgot to mention. These voltages can now be keyed in manually if you'd prefer to do that rather than use the sliders. Additionally, the voltages are color coded. As you move up, they will change colors to indicate whether your voltages are safe or getting to the not-so-safe range.
With regard to the WiFi module:
Those are ideal, perfect-condition numbers though. In ASUS' real-world testing, they're seeing more like 300-450 Mb/s transfer rates. The module also has Bluetooth 4.0 built-in. ASUS also points out that the positioning of the WiFi module's location is optimal from a lack of interference perspective; if it were closer to, say, the GPU(s), there would be increased heat and interference.
At the end of the Up Close and Personal section:
As you've seen, there are quite a few fan headers on this board. All told, there are eight fan headers - 1x CPU fan header, 1x CPU OPT fan header, 3x Chassis fan headers and 3x Optional fan headers, all of which accept both 3-pin voltage controlled and 4-pin PWM fans. There are also three OPT TEMP headers for plugging in three thermistors (not included).
