- Aug 25, 2014
I will be building a new PC within the next month, and I'm trying to decide on a video card. The PC will be used for HD video editing and processing, with high-res photo editing as well. I would like this build to stay relevant for the next 3-5 years, and not need to upgrade the GPU because of the increased demand of advanced editing programs and higher-res video.
The cards I'm looking at are:
EVGA GTX 770 4gb Dual FTW ACX at 1.08 ghz (04G-P4-3776-KR) for $460
ASUS GTX 780 3gb Direct CU at 889 mhz (GTX780-DC2OC-3GD5) for $510
EVGA GTX 780 3gb Superclocked ACX at 967 mhz (03G-P4-2784-KR) for $550
EVGA 780 6gb Superclocked ACX at 967 mhz (06G-P4-3787-KR) for $580
The cost is a slight issue, but seeing as how the difference between the cheapest and most expensive card is only about $100, and the total build will be around $2700, it's not that big of a deal. I'm going with the i7-4930k, with an ASUS X79 Deluxe motherboard with 32gb of RAM.
What I'm wondering is, what difference will a 6gb VRAM make when rendering large, processed HD videos? Also, the 770 card has a higher clock speed over all of the 780 cards, will this make positive difference over the 780 cards? And, does a card being "superclocked" mean it will run hotter, because I plan on using a Phanteks PH-TC14PE_BL 78.1 CFM CPU Cooler, rather than a liquid cooling system.
Thanks in advance for any advice.
