PROJECT LOG [Build Log] The [P]retty[O]btuse[S]leeper by Duality92
Duality92
Pretty
Obtuse
Sleeper
HARDWARE
CPU : Intel i5 8600K with Fanless Phanteks PH-TC12LS
Motherboard : Gigabyte Z370N-Wifi
RAM : Team Group Nighthawk White 2*8GB 3600/18
SSD : Crucial MX200 500GB m.2
GPU : Gigabyte GTX 1070 Mini OC with Li-Heat 30cm B-type riser and 3D Printed mount
PSU : HDPlex 400W HiFi DC-ATX with brick
Monitor : 15.6" 1366*768 built in with HP Pavillion 32q 2560*1440 IPS external
Case : Eclipse 1500C
So here's the case in all it's glory, it's an Eclipse 1500C Point Of Sales (also called POS), gives you the reason why I choose the name too! :D
These pictures are after a good bath there was so much dust in there, it needed to go for a dishwasher cycle! pictures are with the monitor disassembled, it was a touch screen TFT 15" monitor, which I won't be using.
Happy to announce this project will be in collaboration with HDPlex with one of their 400 DC-ATX Hi-Fi power supplies along with a power brick to power it as well as Gigabyte who will be supplying a Z370N-Wifi motherboard and GTX 1070 Mini OC!
Did someone say sleeper? I'm game. Nice Idea on the POS case. Looks like you have a a clean slate to work with more or less.
What will you be doing for a monitor? Just using a external one? or will you mod the case to fit a better monitor?
I'll be removing the factory 15" TFT touch screen and 3D printing a new bezel to fit a laptop 15.6" 1366*768 LCD and controller to have it all internal and use that as a second monitor, then have a HP Pavillion 32q as main display :)
Laptop LCD built into the frame instead of the stock 15" TFT. Looks much crisper than that stock display and will serve well as a secondary display :)
