- Jun 22, 2003
- Canada
Hi,
I started C++ not long ago and I am having trouble with an assignment. I am susposed to read from a file a list names in the format.
num (number of names in this list)
"surname initial,first name"
.... until there are num records
I am then susposed to sort the list using quick sort first by surname and then by first name. After sorting the list I have to display the list of names in upper case letters and proceed to sort the next list of names in the file until end of file. I think I am finished everything except the sorting. I am totally stuck and have no idea how to do it
Here is what i have done so far
Here is the assign_3_data.txt file
PHP:
#include <iostream>
#include <assert.h>
#include <iomanip>
#include <cstdlib>
#include <string.h>
#include <stdio.h>
#include <fstream>
#define MAX_NAME_SIZE 50 // Maximum character length of a full name
using namespace std;
typedef char *charPtr;
typedef charPtr *nameType;
// Prototypes
nameType sortNames(nameType names);
nameType createNameStorage(unsigned numNames);
void displayUpper(nameType names, unsigned numNames);
void deleteNames(nameType names,unsigned numNames);
void quickSort(nameType names,int start,int endInd);
nameType names;
names = new charPtr[numNames];
assert(names != NULL);
return names;
void displayUpper(nameType names,unsigned numNames)
for (int jj = 0;jj < numNames;jj++)
for(int ii = 0;names[jj][ii] != '\0';ii++)
if(names[jj][ii] >= 'a' && names[jj][ii] <= 'z')
cout << (char)('A' + names[jj][ii] - 'a');
else
cout << names[jj][ii];
cout << endl;
for (int jj = 0;jj < numNames; jj++)
delete[] names[jj];
delete names;
// Does not work
void quickSort(nameType names, int start, int end)
int i = start, // set i to the start of the interval
j = end; // set j to the end of the interval
char *mid = names[(start+end)/2]; // pick the middle value as the dividing point
char temp[MAX_NAME_SIZE];
while( i <= j ) // loop while i and j do not overlap
while( names[i] < mid ) // search for a value greater than or equal to the mid value
i++;
while(names[j] > mid) // search for a value less than or equal to the mid value
j--;
if ( i <= j ) // if i is less than j, swap the two values
// temp = names[i];
strcpy(temp,names[i]);
names[i] = names[j];
names[j] = temp;
i++; // increment i
j--; // decrement j
if( j > start )
quickSort( names, start, j ); // recursively call quickSort for interval on the left
if( i <end )
quickSort( names, i, end); // recursively call quickSort for interval on the right
int main()
const int noNames = 0;
nameType names;
unsigned numNames; // Number of names in a group
char nextList; // Decides whether to sort and display the next group of names
char Buffer[MAX_NAME_SIZE]; // Holds full name
cout << "This program gets a list of names from assign_3_data.txt and then it sorts" << endl
<< "and outputs the list of names in upper case letters." << endl;
// Open file that contains list of names
ifstream inFile("assign_3_data.txt");
if(!inFile.eof())
do
inFile >> numNames;
// Check for no names in a list
if (numNames == noNames)
cout << "No names in this list" << endl;
// Preform sorting/display only if numNames is not 0
else
names = createNameStorage(numNames);
inFile.getline(Buffer,MAX_NAME_SIZE);
// Dynamically store the names
for(int jj = 0; jj < numNames;jj++)
names[jj] = new char[strlen(Buffer)+1];
assert(names[jj] != NULL);
strcpy(names[jj],Buffer);
// quickSort(names,0,numNames-1);
displayUpper(names,numNames);
deleteNames(names,numNames);
// Ask if user wants to sort next list of names if not at end of file
if(!inFile.eof())
do
cout << "\nDo you want to sort the next list of names? (y/n)";
cin >> nextList;
// Error checking
if (nextList != 'y' && nextList != 'Y' && nextList != 'n' && nextList != 'N')
cout << "Invalid choice";
}while(nextList != 'y' && nextList != 'Y' && nextList != 'n' && nextList != 'N');
// exit if end of file
if (inFile.eof())
nextList = 'n';
}while(nextList == 'y' || nextList == 'Y');
if(inFile.eof())
cout << "\nEnd of file";
// Close file
inFile.close();
return 0;
PHP:
30
Yuen V, Daniel
Bedard B, Jason
English C, Robert
Ghani D, Saem
Zhang W, Li
Cheng A, Chi-Ho
Ding B, Naichun
He E, Qiushi
Behnoosh J, Ali
Hui F, Calvin
Imanuel G, Toar
Koufakis H, Tom
Myles N, Jeffery
Rubenstein O, Joshua
Kwan I, Jason
Lee J, Ivan
Yuen V, Danial
Liu M, Mi
Tian S, Zue
Abtin A, Farbod
Lin K, Ling-Yu
Shum P, Wai
Smirnov Q, Rostyslav
Tian S, Xue
Tian S, Guo
Supangkat R, William
To T, Man
Castro K, Monica
Chen L, Jin
Wang U, Songzhao
1
Wang U, Songzhao
0
2
Tian S, Xue
Tian S, Guo
3
Tian S, Xue
Tian S, Guo
