- Nov 19, 2007
- United Kingdom
Thanks to JamesXP he helped me find these bits. My original budget(didn't think i would need thermal compound + PSU) was £280
All of the following below comes to £316
Could people help me find these items for cheaper, cheaper the better. Remember i live in the UK!!!
AMD Athlon 64 X2 Dual Core 3600+ (Socket 939) - £32.00 - http://www.overclockers.co.uk/showproduct.php?prodid=CP-213-AM&groupid=701&catid=6&subcat=567
Thermalright Ultra-120 eXtreme 120mm heat sink - £47.00 - http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=693833 + http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=676579 + http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-SY&groupid=701&catid=57&subcat=4
Arctic Cooling MX-2 Thermal Compound - £5.00 - http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-AR&groupid=701&catid=57&subcat=27
Arctic Cooling Arctic Fan 80mm Fan - 4-Pin - £8.00 - http://www.overclockers.co.uk/showproduct.php?prodid=FG-009-AR&groupid=701&catid=57&subcat=819
450W Corsair VX Series PSU, ATX - £45.00 - http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=644038
512MB PNY 8800GT PCI-E - £155.00 - http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=698278
I am also looking for a router i have found 3 linksys ones but dont understand what's what about them, what ones the best. I have a connection where i can get 2000kbps allway up to 8000kbps, on average it is on 4500kbps
There are four computers what connect to the internet, and we run i think cat5 Ethernet leads. It has to be wired!!
http://www.ebuyer.com/product/83646
http://www.ebuyer.com/product/45295
http://www.ebuyer.com/product/54774
