exactly
donny_paycheck said:
It's a small chip. You could use some small chip heatsinks on it that you can get at www.1coolpc.com and attach them with arctic alumina adhesive
Hey how did you know exacly what I was going to do? At this time my ASIII an AS alumina adhesive are traveling from USA to Brazil he he... I already found heatsink for it, just will cut a bit becouse the chip itself is too delicate, if you make something to much large or tall, it can "pop off" your chip in an accident... So I´ll put a litle heatsink and directionate a 60mm fan to trough an acrilic bracket extension modded just for it....
Unfortunately I don´t have the IRed Cam.. But the Photo is here:
http://www.killroyishere.com/cusl2.htm (wouldn´t fit in the forum board)
I wish you the same luck searching for a phot of your boards too, but i don´t think is something easy to find...
Here is the transcription of my mobo hottest poits.. I compressed it becouse we cannot post files bigger than 300x300... I picked the my mobo photo and circled the hot points in red... Maaan i Have a furious overclocking project in my mind he he
PS the photo became horrible compressed... If someone want to see the hot spots in the real decent photo ask me and i´ll send by e-mail Ok!?
