- Sep 3, 2003
- Californa
I just got a new Thermaltake Xaser II 5000 series from www.Newegg.com. When i got it i opened it up and then opend the front panel to the power switches when it just fell right off... I couldnt belive it, the hole case is like a freekn tank, it is almost all made out of steal. When i picked up the panel i found 2 little plastic stubs next to it. I looked to see were they came off of. I then realised that the were the hinges to the front accses door. I couldnt believe what i saw. The things must have been like 1/8 of an inch. They were the only things holding the 6 ounce front panel on. So i sent it back and now im stuck without a case for all my new comp parts. I was thinking of geting another thermaltake case (Thermaltake Xaser III Lanfire) but im not sure if i realy want to do that seeing how the first one i got was poorly designed. I dont want the same thing to happen though. So if some one could tell me a little more about the Lan fire case that would be great... or recommend a different one.
