- Mar 11, 2003
Alright, so my Mg2 started leaking this morning. I take it apart, and replace the O-ring, then, I try another O-ring, then I try them both. Leaks in all 3 configs.
So, I stripped one of the screw threads that mount the front part of the pump to the main part. I rigged up a fix for that, but I need to make it stop leaking. Right now I'm running it submerged, but this is far from permanent.
Does anyone have any suggestions?
Assuming I can't fix it, would a mag3 or two via aqua 1300's in series work better?
