- Jul 31, 2004
Intel seems to have added a bunch of bugs to their iwl5100-series drivers, so I have a Netgear router with DD-WRT on it, which I use as a wireless client in my dorm room, and plug my laptop into it via ethernet. I'm currently limited to 802.11g using the router. 802.11n spec, AFAIK, explicitly disallows running 11n without WPA2 security.
The network in my school is an open network (yay for letting hundreds or thousands of technologically ignorant young adults spray their information over the airwaves since 99% of the sites they use are probably not using SSL). I'm not too worried about the open network myself, since every site I use now is either full SSL or at least uses SSL for the login, but I'd like to get the router to connect as an 802.11n client (rather than 11g), but DD-WRT seems to be sticking to the 802.11n standard and not negotiating a connection without WPA2.
Should I attempt to convince the school's IT department that they should stop violating the standard and implement a key (even if it doesn't provide much security because everybody will know it), or is there some way to bypass DD-WRT's standards-compliance?
