- Jan 4, 2024
@Holdolin , fyi the Einstein GW gpu task credit temporarily got bumped from 5000 to 10000 points per task. I tried this out on my Radeon VII and I could get about 2.15M PPD per card. See here.
Wondering what your Radeon VII Pro with twice the FP64 compute of consumer VII card will perform as there is some advantage with higher FP64 speed. Anyway just keep you informed since Milkyway gpu apps ended and you may be itching to put your Radeon VII Pro to some good use . If you can get higher PPD than Milkyway, that's awesome. The task doesn't sip much gpu power but requires fast CPU for better throughput.
