So okay i bought for my build the ENERMAX PS-GAL850 EGA850EWL GALAXY 850W SLI POWER SUPPLY and form specs it should run nice and sweet on my box
I got it from a company called " EWIZ " <-- stay away their service and return is the worse i have ever experieced and saw
The first power supply i received has power issues like
1. i power up a game and it will start to beep, so i check the code for the power supply and it says PSU - ON, LED - RED, Two Beeps interval - a. PG Power Good signal abnormal - b. System loading lower than PSU minimum output load requiremnt*.*
LOOK AT MY SIG
Now after a month i get my replacement, i had to pay to ship back to them and they took their time with the RMA process and getting me a power supply back
Now i hooked it all back up
Now i get PSU status - ON, LEC - RED, Buzzer - short beeps
a. PSU Fan fail warning FAN RPM < 450rpm
b. Please turn off the sytem and check the PSU fan
the fan is running on the PSU what the hell is this all about
ewiz.com suxsssss
now i have to call them and just let them freaking have it..
i dont think at this point i can be calm
i took out all my video cards and tried one by one
i took out all working parts and started from scratch just to make sure
i swapped out my harddrives for other SATA drive, also cables
i even put in extra harddrives to make sure its not that the system is over kill
i went in and did a clean install with Vista Ultimate and Direct X 10 from windows xp still craping dame beeping noise just drives you up the wall
my motherboard has the PSU on the board, fan turns so i know it works and during the beeping the fan is still running so wasup
i ran it with a pencil holding the reset buzzer for an hour, system did not crash, games played, and i even reloaded it several times but pull off Pencil and Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep
LOOK AT MY SIG
ewiz.com suxsssss
