- Jun 14, 2002
- Hampton Roads. VA
Here ya go guys, I finally have some pics of my completed watercooling setup. You may have already seen some of them, but I'm going to repost some in this thread.
It's about time I joined the party!!!!!!!!!
BTW, in the past when I left seti crunching, my cpu temp would get up to 51c easy. I've been running Seti for about 2 hours now, and it hasn't got past 39c yet. My ambient is currently between 30-31c. It normally runs at about 33-36c. I'm very impressed. I'm only using motherboard monitor to give me the temps, so I know they aren't acurate, but they should be to scale okay when you compare both my before WCing and after WCing temps.
Here is some info on my ghetto RES. I cut a small triangle shaped hole in the corner of the top for teh pump plug to fit through. I then cut a small piece of cardboard int eh shape of a triangle that was the same size as the hole. I then put on some JBweld to seal it. OF course you can't see the cardboard now. For my fill hole, I cut the top of a 2 litter bottle off and used that. The barb at the top and the side need no explanation.
One more thing. JBweld has got to be on of the best inventions EVER.
