Another update, minor as it may be, we got the paint sprayed on the front cover and side/top cover, damn it looks good
We learned something about Dupli-Colour's "Metal Cast" paint today, unless you're painting chrome, forget the instructions. Bam sanded down the side/top cover today, cause neither of us were very happy with the way the first paint job turned out, so we started over. Hey, we were painting the front cover anyhow, so why not redo the side, which we didn't like anyhow?
We formed a new plan, the side/top would be done by the book, the front would get one heavy coat of primer, one heavy coat of paint. The primer coat would tell us if we were on the right track. The first time around, we went with multiple light coats of primer, followed by multiple light coats of paint. It just wasn't working for us, it looked good, but not "GOOOD". I took on the front cover with the one coat, that way, if it was screwed up, Bam didn't have to sand it down again(hey, I'm a nice dad).
Josh sprayed four light coats of primer on the case, in about 50 minutes, as per the rattle-can's instructions, then I sprayed one heavy duty coat of primer on the front cover, evenly, I kept spinning that puppy around, until it looked soaked. Then we waited 1/2 an hour before spraying on the paint, as per the can's instructions. Josh got 2 light coats on, then I sprayed one heavy duty coat of paint on the front cover, evenly, until it looked soaked, once again. The primer had "self-leveled" the first time around, so I figured I'd risk it.
Josh was spraying on his 3rd coat 10 minutes later, when I looked over at the front cover, the paint had self-leveled too, so I told Josh to use up the rest of the can, soak that puppy. The light coats were looking like they had a rough surface to them, whereas the heavy coat had self-leveled and looked wet, even when dry. He polished off the can on the top/side cover, and we headed upstairs to wait till they dried a bit. The results blew me away! DAMN! This paint rocks, when heavy coats are applied. I wish the pics did the paint job justice, if it ever gets sunny here again, I'll post some pics of this puppy in natural light. I tried to get some natural light on it by the patio doors, but it was cloudy today, so it doesn't really do it justice.
This paint system is designed for chrome, and is supposed to give a chrome anodized look when finished. When painting anything other than chrome, the "ground coat"(primer) has to be sprayed on, call it a fake chrome base. We discovered that a heavy coat, that self levels, and dries smooth, gives the best base. I tried it out on a wrench, just for kicks, no prep on the wrench, just wiped it down with a tack cloth and then sprayed. I'm amazed, this schitt really does work! I got a couple pics of the wrench in here too, excuse the partial footprint on the middle of the wrench, Bam, the hammer-head, stepped on it while it was wet. I'll post more pics later tonight, once I get the fan bolted back in, and the front cover bolted on, should look sweet. This really has to be seen in natural light, a flash just doesn't do it justice.
Anyhow, on with the pics, enough of my rambling......
...the new paint on the front cover, no polishing yet, this will buff up nice after it sets hard...
...side and front together...
...side by itself...
...here's a few pics of the wrench, once again, I'm going to get some pics of this in natural light. We had a wee bit of paint left in the can, so we tossed it on the wrench for kicks, just to see if it really did what it said it did. It did. Man, it looks like a freshly dipped candy-apple. I love this freakin paint!
...the bad side...
...the good side...
I hope everyone else is enjoying this ghetto mod as much as BamBam/Josh and I are. We had a look through his "Transport Encyclopedia" this aft, between coats, he's still not sure if he wants a Mack bulldog on the front, he loves Freightliners. Problem for me is finding a Freightliner emblem that will fit on the front of the case. Anyone know of where such a beastie can be found? I need a smaller emblem, maybe no more than 5 inches wide, six inches tops. I just know that the little schmuck will accept nothing less than a Freightliner emblem, just to make me work harder to find something. Kids, whatcha gonna do? Till later, adios.
