As frequent readers may recall, I have been trying to extend my success from a reliable 968 @ 129 fsb, to the slightly better 1000 @ 133 fsb since that yields a pci bus that is perfectly on spec for peripherals other than the agp. I previously projected that it might be my memory, which is older memory that I got with my previous processor, a Step p2 333 oc'd to 500.
While some thought that possible, most wrote it up to the limitations of the cBO in general and the p3 750 in particular.
I write this for those hardheads out there who persist at trying to make things work.
I am now coming to you on a 1 gig processor. The only change that I made was a change in the sdram latency setting from "auto" in bios, to "2." The computer has booted everytime with these settings although I did bump the voltage up to 1.85 when the computer locked up in "Black & White" at a lower voltage.
While this may not be stable as set up, I may have established that memory is a factor. (It was no boot at 1035, by the way!)
Does this sound like a memory thing that better memory might stabilize?
anvil
anvil
