There is everything that the Pro version had (or at least I can't see the difference). The only problem is that some things are harder to find and to make some things, you need the old control panel. Moving between old and new settings is annoying as you can find 2-3 the same options in different places.
It's not bad when you adjust everything, set shortcuts, etc. I also recommend updating the Win11 as there were multiple improvements since the release. Some things I was complaining about were fixed.
