-=sky=- said:well....i have the crossover cable already
but the problem is that the two computers never see each other even in network neighbourhood(it is set to be in the same network)
what's up with that?
thx
su root said:Make sure A: The NetBEUI protocol is installed on both computers, and B: they both have IP addresses (192.168.0.x is good) C: File/Printer Sharing is installed
This will ensure they can see eachother and share files, printers, and internet. If you are looking to play games, install IPX/SPX on both aswell, it's a common protocol.
Hayduke said:Ok I figured it out. I've been overclocking so long with no problems I didn't even think about odd bus speeds. I dropped my PII unit back to 100/33 and everything works fine. That processor won't handle 133/33 and the NIC won't handle any odd bus speed at all so I'm stuck at the stock 100/33 or 400Mhz. ARGH! Oh well at least my 600 PIII is still ok at 800.
Anyone care to recommend good NICs for overclocking? These Diamonds have got to go. I can't stand running stock. It feels so.... weird!
