The best I could get is 4.2 ghz at 1.2V. If I raise the ghz and/or both my CPU will reboot. I guess that's the best I'm going it get.
Sorry for another reply. Do you think it's worth exchanging my CPU. I have 15 days to take it back. People suggested I use Noctua NT-H1. Is that really a lot better then Artic 5 silver? Thanks again for all the replies.
David
Ok. I asked the store yesterday if I can exchange it and they say yeah. They kind of have a liberal policy. I didn't tell them I was running at 1.4v though.
I wish I kept my 15 3570K.
Ok hold on!
The CPU is fine. There is nothing wrong with it.
Instead, grab some better paste, and remount the H100 on it!
there's no reason to return a good working CPU
Problem with exchanging it is you may get one that runs hotter.Ok. I asked the store yesterday if I can exchange it and they say yeah. They kind of have a liberal policy. I didn't tell them I was running at 1.4v though.
Paste is only going to help a degree or two...that isn't the issue.
The difference between as5 and other paste is like 1.5 degrees. Some act like as5 is an insulator or something, lol.
Either way, when his new TIM arrives, he can remount the cooler
Also, how did you apply the AS5 in the first place?
Line or dot method?
I'm a newbie. What is TIM? Is it available yet? I applied AS5 using the line method. Is the dot method better? Is it bad to have to much thermal paste on the CPU?
David
Silver_Pharaoh, thanks for the explanation about the paste. I have another question. Real Temps read outs and the read outs from Gigabyte Hardware monitor about 15-20 degrees difference. The Gigabyte Hardware Monitor are lower only gives one CPU reading.
