Hello guys, (at the beginning sorry for my english language) today i open CPU-Z cause i want to overclock my G3258 and I noticed a voltage is up 1.744 V, i think it isn't normall. What shall i do now?
Screenshot below.
On the motherboard voltages, CPU VCORE is what you want to watch for your CPU core voltage. What heatsink are you using?
Does your BIOS on the MSI B85M-G43 have overclocking options for the G3258?
+ and - gives nothing, i try everything but still nothing, maybe it's problem with bios version?
Okay sorry for that i will remember. @forget that all, now i can change CPU ratio What shall i do now?
Now you test. Use something like Intel XTU (a stress test) to test the overclock stability.
Start by upping the multiplier and then testing.
If it passes, up the multiplier again.
If it fails, up the vCore and test again.
Go until your temps are approaching 85°C or vCore is approaching 1.4V.
I don't mean to hijack but my vcore shows 1.760 in HWMonitor but CPU-Z says core voltage is at 1.198. Maybe my board isn't supported? Running prime95 for 2 hours with no issues. Any ideas?
