indigoblades
- Aug 9, 2013
[RESOLVED]
I am new here .... not sure how to set my signature up but below is my system. I used the great Bulldozer guide by Stevenb to OC.
http://www.overclockers.com/forums/showthread.php?t=688663
My AMD-8120 bulldozer needs lots more volts than most (1.6v), i needed 1.45v to boot into windows maybe one step more @ 4.5ghz .... i dont think mine could 4.5ghz Prime95 on air or a small water system. For my mobo and bulldozer i get a consistand 0.075 droop DURING PRIME so 1.6v set sees 1.5 to 1.525v. i can post a pic of my run. Any tips on how to lower core volts appreciated. Or if high volts dont matter if temps fine and not big voltage overshoots tell me. i am more interested in how to keep the volts down day to day than what a see on validation run. i haven't spent time uppin my fsb coz my volts are about at the limit i think. if others are runnin higher volts please tell me. i have seen others running much higher temps than i am.
I also have DFI-Intel Q6600 system and a Z77-DS3R/i5 system (hackintosh) but neither is overclocked. i used to overclock the old AMD X2 and opterions with a DFI mobo. ... probably about 20 to 30% depending on how good the cpu. on them i would lower the memory multiplier and the hyper thread bus multiplier and find what the cpu could do first using the fsb. then bring the hyper back up and try to find a good memory match. i am new to bull dozer and never over clocked an INtel. In the old days i never had enough cooling head room to add many volts ... for my bulldozer i used ur guide just the first steps only changing multiplier and Vcore... once i decide what clock i want and what volts are good ill do the next step.
I have got a 6hr PRIME95 stable 4.5Ghz OC on my bulldozer from using Stevenb's guide ... i just did the multipler not the fsb coz i feel i am at voltage limit (1.600 vCore set). i basically turned off turbo, saved .. and found out what multipler is stable at what volts thur his methodolgy. just upped volts each multiplier step. then did final 6hr run when i passed a 30 min PRIME run before i played with fsb, northbridge and other multipliers ... on my system PRIME would have a core, usually #7 fail the test, or i would see the thread die in resource monitor & Prime act funny. my pc never crashed. .... my volts did go up a lot to pass PRIME95 going from 4.2 to 4.5. it will run most stuff at 1.475v but prime needs lots more. my feelings are MY 8120 needs lots volts and it droops alot during prime ... i did some runs with power savings off but didnt see a huge diff, i left most power saving on in the end because day to day i would just soon it throttles down .. i didnt see huge difference with em on, maybe a voltage step or 2.... my volts required are high (set 1.6v) but i have excess cooling, one big heater core and a thermalchill triple all getting cool outside air, two of my five fans are 5.5 inches ... its also not air conditioned so my house stays in the 80's except at night .. my highest core temp is 45C spikes very occasionally (if volts spike to 1.625) & typically 38C if volts are bouncing 1.58 to 1.6, with prime it stays about 39C since prime95 has 0.075v droop (1.500-1.525)... but if i play games, theres less load on cpu than prime, but then there's no vdroop and it will stay 1.58 to 1.600, typically bouncing 1.58 to 1.600 ... . ... stays about 37c tho when vcore is 1.6 .... HWmoniter says my highest volts are 1.632v with 50C my high temp. those are spikes. I am at the point i should ask some questions now. My volts are so high i am not sure if should drop to 4.3 GHz & optimize fsb (i could drop vcore 2 steps to 1.55 at 4.3Ghz) . i got coolin headroom at 1.6 set, but i know i will use it up if i go higher. i feel im at max volts i wanna put in. .... normally when i over clocking after a long final stability run i would up my volts 1 or 2 steps for stability but my volts are so high now .... i could use LLC set to gigabytes 'extreme' (its on regular now) but my feelings are ill turn the processor down 2 volt steps and LLC will put in 2 more steps and the cpu see the same volts. i would only use LLC if got rid of droop for PRIME95 runs only but day to day it was lower ... in the old days overclocking 2 core cpu's, i feel getting 2 cores maxed is very believable in real world ... maxing 8 threads 100% i think is very artificial so i feel if PRIME passes for hours that's stable & no need for safety margins ... most software just cant multitude that many threads 100% ... as for stability my experience with windows is it crashes randomly with a stock system so a crash every 2 weeks isnt a good measure FOR ME of if my overclock is stable.... i am forced to stress test for stability. Anyway unless i persistently crash its hard to tell if that's cpu stability or just windows.
IF One has lots of cooling which i do, how much would u worry about volts that high. Again i never had lots of cooling before so i never over volt'd much. also am i correct to worry about the volts it sees in HWmonitor not the volts set. i have noticed my temps now are more proportional to the voltage changes not the threads used or cpu load. i have been watching it closely in will playing skyrim with other stuff running in the back ground. My skyrim is GPU bound mostly but i can go to places that are CPU bound too. its got lots of mods and ENB so it loads up 4 cores pretty good. Also i assume TMP2 on Hardware Monitor is cpu socket temps (about core +12C on my motherboard ) i trust the core temp more, so my standard is 65C is the limit on core temp and the other isn't critical.
again, it would boot fine into windows at 4.4, 4.5ghz at 1.45 volts. one more volt step & it ran skyrim, & simpler stress test and like super pi. I didn't have OCCT at the time i over clocked but i followed stevenb's guide up to the point where u traded multiply for fsb speed ... my prime95 seems to stay consistent 1.500 to 1.525 with 1.6 set ... if i lower it prime will fail a core.
Any tips how a typical my volts are is appreciated. also i read AMD bins differently now... my AMD-8120 was bought in dec 12, Rev OR-B2, so maybe they don't overclock as well now. i am not unhappy, i got the cpu for about $125 and the mobo was free in a microcenter special. i can get 4.0 ghz with moderate volts which is fine, and that's what my guess what others could get with moderate $50 to $100 after market air or water cooling set up.
Also, since i am new, I am pretty good with Water Cooling, if anyone has questions ... i have a masters in Mech Engr with specialization in Thermal-Energy which helps a lot. Most to the data in reviews is insufficient to CALC what a Water cooling parts will do in a system(before u buy it). But my view is 80% is just how many fans u have if other components decent.
Thank You for the help.
GA970A-UD3, AMD-8120 4.5ghz (1.6v set on Vcore), HD-7850 1050Ghz, TX850 watts, 16Gb mushkin ram set at 1333, water on CPU & GPU, 2 rads, 5 fans, MPC355 pump
