- May 12, 2015
Yea you guys heard me 17 years old, I have been re-using a dangerden Maze 3 water block since the athlon xp days. If you ask me how i managed to put it on a 4790k or a e8400 or my athlon 64's i had its easy.. I simply used the original nylon screws and the coil springs it came with and cut 4 arm brackets and drilled holes in them and walla.. Instant water block recycle, ive also been using my 120mm radiator for 17 years and the Eheim 1080 i think its 1080 i cant remember pump too, it has been runing non stop for almost 20 years..
And well it just plain frigging works.. So i havent spent a dime on cooling. My 4790k can overclock to 4700mhz at 1.25v and be stable 24.7 at that. Why should i get a new water cooling system you ask ? TBH i dont know why maybe im just tossing money away on something that works but i thought maybe i should upgrade.. At LEAST upgrade the radiator to a duel or tripple radiator instead of my single 120mm one. Im also looking to upgrade from my 14 year old case and i finally want a case large enough to hosue water cooling. My main concern though is the Eheim pump is a magnetic pump, and putting that inside my case would this magnetic field affect the computer parts ? I've always wondered that as the field back in the days was strong enough to cause my CRT monitor to be wavy when put close to it.
So i dunno, can you guys recomend me a good water cooling setup. With a block,radiator and pump that ISNT prone to leaking, ive seen some of the cases on newegg that come with a water cooling setup built in and reviews some of them mention they leaked and im not about to have my 800$ gpu destroyed over that. Ill keep my reliable setup over that. I might also want to watercool the 1080ti but im not sure yet.
Thanks a bunch.. Oh and for those of you that want to see here isa pic of my dangerden maze 3 waterblock
