kg-7 and thurstmaster joystick
Kendle666
Hi guys,
I'm having a small proble with my KG-7 and a Thrustmaster usb Joystick. The joystick works fine on my kt7-raid under XP but when I plug it into the usb on my kg7 under win 98se it doen't appear. I know the usb works because I've used other things and they work ............also I go into Dev. Man., and look under the Via usb hub, I can tell it at least is sending power to the joystick ...................any Ideas?
Duron [email protected] (9x133) alpha Pal 8045
512 meg micron ddr pc2100 (2x256meg)
G2mx
40 gig 7200 WD
20 gig 5400 maxtor
Kendan
Senior Punk
Dark side of hell
go to this page then scroll down to miscellaneous patches. there is a patch for the usb force feedback joystick problem. hope this helps. By the way check out the rest of that site. It is the best resource for the KG7.
