- Oct 2, 2001
- Corona, CA
Is there any way I can seal it from the outside? Like a glue type?
=ACID RAIN= said:From what I've seen, teflon tape can be hard on pump housings....in other words, crack it. You best bet (and don't be lazy) is to take it all apart again, reseal all threads with RTV sealant (just silicone sealant), and let it dry for a few hours, then carefully put eveything back together and start over. 1 drop of water is not acceptable!
I can't fathom this, PFTE a.k.a. Teflon tape serves two purposes when making threaded connections:From what I've seen, teflon tape can be hard on pump housings....in other words, crack it
That explains it, should have thought about the "DUH" factor (not that I'd ever do one of those - )Guys, the only reason I say what I say about teflon tape is because not everybody knows to use it in moderation
