- Aug 25, 2002
- bleek abyss
In the everlasting search for the ultimately cheap and ez pelt power supply i have reached this point.
Peltier = 226w 15v @ 24amps
I have found a 12.6v @ 25amps transformer.
http://www.allelectronics.com/cgi-bin/category.cgi?category=790500&item=TX-12625&type=store
Capacitors from 50,000 to 210,000uF.
http://www.mouser.com/catalog/610/329.pdf
My initial thoughts are....
The transformer will get pretty darn warm even at the draw of 21amps or so. Solution- Add a 486 cooler on it, sit it in direct airflow, or attack a WB to it and the WB be last in the cooling circuit.
The caps (50,000uF ~ 2" x 3.125") are fairly large. Nothing can be done about this. doh
Finding a brigde is the easy part.
What is everyone thoughts?
Whats the minimun uF rating of a cap to get good filtering?
