Hello hello, all time reader, first time poster
I see there are a lot of threads about 10600k and overclock but I have a different problem so to not hijack anyones thread I will make my own.
The configuration is:
MSI Tomahawk Z490
10600k cooled by trusty old Megahalems C with Noctuas
Mushkin 3466Mhz 16-18-18 2x8GB
Everything is left on "Auto" except VDIMM which is 1.35, Enhanced Core Turbo which is Disabled and short/long power set to follow Intels spec as 125W long, 182W short, 56 sec boost time and 140A current. This to my understanding should be the "true" default by Intel spec.
First of all the processor wont hit 4.8 ever, 4.7 sure on 3-4 cores simultaneously but 4.8 never happens. I tried giving it some single thread loads but it looks like the newer windows scheduler brakes up even older games on multiple cores these days, which I clearly remember doing single thread only before some time. So I cannot reproduce true single thread workload and I'm thinking this could be the reason processor is not hitting 4.8. I've seen Gamers Nexus 10600k review and they say running Cinebench R20 single core mode should get you 4.8 on some cores (to verify boost is working correctly) but that is also not happening, dunno if they mess with affinity in task manager or what they do but its not working out for me. I managed to set 4.8 manually all core and it works but seems to need voltage over 1.25 which is a bit much for Megahalems as the temperatures become a bit toasty (but still bearable). Setting "Per core" overclock as 48/48/48/48/45/45 also does not get me 4.8 boost at any time, only if i set 49/49/48/47/45/45 then I get 4.8 and even 4.9 sometimes but that runs a bit unstable.
Now the questions, how would one go about testing if the processor max boost is working as it should? Also, I see everyone is doing all core overclock these days and no one is doing anything like per core 49/49/48/47/45/45 OC, why is that? Is this not possible/not recommended to follow Intels boost logic just to OC it a bit more than default?
And lastly, my voltages on Auto for VCCIO and VCCSA seem a bit excessive as 1.2 and 1.26 respectively. This is without any OC and from what I read those values are pretty high, even the motherboard itself labels anything above 1.15 and 1.2 as "red" when setting it manually so excess 0.05 on both. I tried lowering these to 1.14 and 1.19 and everything seems to be stable and temp also seems to drop a bit, what would you say these should be set on for default?
MSI Tomahawk Z490
