I'm relatively new to the whole overclocking process, I've got a pretty nice build that I did while back but never messed around with the settings. I've been having some bios issue with my motherboard but got it worked out so that I could just OC by increasing the multiplier rather than the base speed not sure if makes a huge difference. When I enable the settings to increase the base speed my mobo stops detecting my sata drives.
Well anyways I'm gonna post some results of what I have so far. The temps were while running Wprime, prime 95 gets a touch higher seen the highest core hit 70. I'm not to sure how good or bad this at first I would get crashes but turned the voltage from auto to 1.4v Everything seems to be working now. I just put in the corsair H110. If anyone has any advice or tips they would like to impart I would like to learn more about this whole process. Thanks (edit: it's OC'd to 4.67GHz just incase you missed it in the img)
Current Build
Motherboard: Rampage III Black Edition x58
Processor: i7 990x Corsair H110 Heatsink
Memory: Corsair Vengence 12/24GB 1600freq
Video Card: EVGA GTX 780 SC
Hard Drive:Samsung 840 Pro 256gb, 3TB Seagate HDD 7200
Case: Thermaltake Level 10 GT Snow Edition
Power Supply: Corsair AX1200
Operating System: Windows 8 pro 64bit
Current Build
