- Dec 26, 2006
- Land of Long Horns
Yeah, check the water pH and if is less tha 6 then it's most likely bacteria...the bugs make water acidic
voigts said:This question has been raised many times before, and the answer that I have read seems to have something to do with the actual plasticizer used to make the tubing. Every other potential cause has been debated and eliminated. The white film strikes all vinyl tubing it seems sooner or later. I have found that Masterkleer takes over 6 months to cloud just a little bit (nowhere near as badly as in darkcow's case), whereas I have had less success with Tygon R3603 as it clouds for me rather quickly. Clearflex60 is the worst in that it will cloud in a matter of weeks.
So if what I'm reading is right. There is currently no known method of using clear tubes with additives and keeping the tubes clear? Right now I'm using distilled + anti-freeze + highlighter dye (for green glow) and my tubes have a white haze after almost 4 years. Also, my tubes have a green tint to them that I noticed when I shut off my pump.
Well, you could use Tygon 2075 or 2275. It does not have the plasticizer used in 3603, Masterkleer, and other common WC tubing, and hence should not cloud, but it's not as clear to begin with. Jackrungh posted this image of 2 year old 3603 alongside new 2075 and 2275.So if what I'm reading is right. There is currently no known method of using clear tubes with additives and keeping the tubes clear?
If that's all that's happened in four years, I'd say your tubing faired fairly well. Which type is it?Right now I'm using distilled + anti-freeze + highlighter dye (for green glow) and my tubes have a white haze after almost 4 years. Also, my tubes have a green tint to them that I noticed when I shut off my pump.
http://imageshack.us/?x=my6&myref=h...owthread.php?t=506575&highlight=tubing+sticky
The full discussion is here,
http://www.ocforums.com/showthread.php?t=506575&highlight=tubing+sticky
BTW, even if you you use straight water the regular clear PVC tubing will cloud eventually as the water replaces the plasticizer in the tubing.
It's fixed now. Thanks for pointing out the problem.Your links don't work otter...
Second one does...
