- Oct 30, 2007
I have not had any virus for years.
All my computers are behind a firewall of my router. I also have AVG and Ad-aware installed on all computers. All security settings in the Internet Options are at the highest level.
Just now, I was watching a new DVD arrived from netflix. Then all the sudden both AVG and Ad-aware popped up windows to tell me multiple Trojan/virus attack were blocked. AVG even listed the names of the files which were detected on open, I clicked the button "remove all unhealed files".
So I thought it was nothing.
Then, when I tried to be sure and to use AVG to do a complete scan, it popped up a window and said "AVG.exe was infected".
I tried to do a full scan with Ad-aware, a window popped up and said "Ad-aware is infected".
I then noticed there is a minimized icon at the bottom right. Something I've never seen before. It is called "Security Suite". I clicked on it, it popped up a window and "looked like" it scanning my computer for spyware. It "found" a bunch of spyware and asked me to upgrade to full version. Of course I am not buying it, I tried to close it but there is no way to do so. I tried to close it in msconfig, and there popped up a window said "msconfig.exe is infected".
I tried to search for solution online, and found internet is unaccessable on this computer. All web page shows "Internet explorer warning - visiting this web site may harm your compute". Well first, I use firefox. Second, all the web pages I had saved before were completely safe. Something like netflix, yahoo, wikipedia etc. ALL pages show the same message and won't load.
Although there is one other page came out of nowhere - antivirone.com.
It took me to a page where it wants me to buy this "Security Suite" which is the icon minimized at my bottom screen.
I tried to go to control panel to check for this program so I can uninstall it if it is there. I found "add or remove programs" will not open.
I tried to go to Internet Options, it will not open either.
I restarted the computer, AVG loaded, but Ad-aware did not. But AVG will not work. I tried to do a full PC scan with AVG, it started, then it ended with "scan finished" in just 2 seconds.
There is also one more thing, there is always this window pop up says "Windows security warning" which I doubt it is really a warning from the windows security.
It seems somehow I got a virus that had disabled not only majority of my computer functions, but also disabled my AVG and Ad-aware, and the internet. It tried to make me believe the only way to fix it is to buy this "Security suite" from this antivirone.com.
What now?
I am typing this on my laptop. Looks like other computers on the same network have not been compromised yet.
What now?
