- Dec 7, 2004
ok well i play EQ2 on balanced settings and untill like today (got comp 2 days ago) i had like 0 stuttering. today i didnt get stutters but got some slowness (never had it before) and my goal is to play EQ2 on balanced graphics w/ 0 stuters and now slow downs..
System Information
Time of this report: 12/7/2004, 01:16:04
Machine name: YOUR-13E050B673
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: VGC-RA820G(UC)
BIOS: BIOS Date: 10/19/04 13:49:27 Ver: 08.00.10
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 267MB used, 2194MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X300 Series
Manufacturer: ATI Technologies Inc.
Chip type: RADEON X300 (0x5B60)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5B60&SUBSYS_0005104D&REV_00
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6490 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/26/2004 20:35:58, 214528 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 10/26/2004 20:35:38, 820224 bytes
Device Identifier: {D7B71EE2-1820-11CF-A76A-0F20A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5B60
SubSys ID: 0x0005104D
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
thats my comp specs from DxDiag.. now what should i over clock and what to? also is there a program i can do that from XP? cause my bios is stupid and i dunno how to get into it (ive tried f1 f5 f6 f8 f9 f10 f12 and del wont try others cause its too late) and i hear that graphics cards are easier to overclock if you use a program from xp (Nvidia cards anyways)
yes i wanted the nvidia but my dad bought it and gave it to me so beggars cant be choosers.. i COULDA gotten the 6800 GT but we picked up the wrong model.. so plz no falming me on that..
so i really want a 2.5 GHz and a little faster ram.. thats bout it tho..
BTW its the new Sony Vaio Media Centre.. its a great comp =)
System Information
Memory: 1024MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1002
Device ID: 0x5B60
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
