- Apr 29, 2002
parkan said:David, I think you should update Debian to being 3.0 latest (sure, woody is not official but everyone uses it anyway)
David said:Windows Filesystems in Linux
- FAT32 - Linux has full FAT32 read and write abilities, and will work fine with windows FAT32 partitions.
- NTFS - Linux has, by default, the ability to read NTFS partitions but not to write to them. Write support can be turned on (requires changes to kernel config) but will damage the filesystem, so that Windows will go crazy next time it boots.
David
parkan said:
By default? eh? Linux doesn't have anything by default. Many distros load the module by default, yes, but it doesn't mean that it is built-in.
krazykraut said:what is best for person with little cash and nos nothing about linux
David said:Disk Imaging
In some situations you may want to image a file/partition to another file/partition. This can be done with dd, found in all Linux distros
dd can be used as follows:
dd if=<source> of=<destination>
Source/destination can be a file, or a device. Eg for the first partition on the secondary master drive to a file called backup.img:
dd if=/dev/hdc1 of=backup.img
You can also specify how much of it you want to copy over. Specify the block size, in bytes, and then how many blocks. For example to copy 100MB from the above example, try bs=1048576 to set block size to 1MB and then count = 100 to copy 100 of the blocks:
dd if=/dev/hdc1 of=backup.img bs=1048576 count=100
kaky0u said:
I got a problem using this.
I'm trying to make an image file from a "M'drake Boot Disk" with this command:
dd if=/dev/floppy of~/linboot.img bs=512 count=1
But it just ain't doing jack. Keeps on about this is a directory. Thought I'd mention Linii nuub.
