What tcp/ip settings do you want for it? Just do `ifconfig eth0 <ip-address> netmask <netmask> up` in a terminal where you are su'd to root, then do `route add default gw <ip-address> netmask 0.0.0.0 metric 1` in the same manner to set your gateway.
Assuming that the router will hand out IP addresses via DHCP (which it should) then you need to type in 'dhcpcd eth0'. That should fetch you an IP address.
It stands for your netmask. The netmask tells the computer how many bits of the ip are used for the network address. The computer assumes that the other bits are used to represent hosts on that network.
