- Feb 12, 2001
- Fayetteville, AR
Ok I am a PC Tech and this is just still baffling to me, I run Windows XP Pro and have a nVidia GF FX 5950XT OC card with the newest WHQL Drivers 66.93 from the nvidia site.
The monitor I use is a '19' Viewsonic UltraBrite a90f+, with the correct drivers installed, supported res's are 800x600 @ 120hz / 1024x768 @ 100hz / 1280x1024 @ 75hz and 1600x1200 @ 60hz.
Now when I go into my nvidia driver settings, the box is checked saying "do not show modes this monitor will will not support" and it shows only 60, I have tried all the NVRefresh Rate fix tools I can find, have also gone into the registry and added new keys and binary values, adding the registry values did work and it DID allow me to have 99fps constant at 1024x768 res with v-sync on like I wanted, BUT it also disabled some of my resolutions, max res went from 1600x1200 to 1280x800.
I want run 1280x1024 on my desktop @ 75hz v-sync on, and ingame I run 1024x768 and want to have vsync on @ 100hz for 100fps.
I have since removed all the Nv Tools and deleted the reg keys and modes I made to raise the default winxp hz settings to 100, but now its still messed up and wont let me pick all my res. I can un/re install the nVidia drivers and fix that easy enough, but them im back to square 1 and still need to be able to actually use the monitors res's w vsync on.
(also) - some of the tools told me that any drivers after 45xx series have the hz override built in, and im able to find this and set it how I want it, but again those in-driver settings do not transfer over in game, this is for CS 1.6 mainly, and yes I have fps_max 100 so on and so forth.
Any Ideas, thx
Any Ideas, thx
