- Jan 27, 2011
Hello guys,
i have a :
CPU: Phenom II X4 945 3Ghz
MB: MSI 740GM P25 (BiosV. 2.5)
RAM: 4Gb Kingston Value Ram 1333Mhz
Zotac GTX 260 AMP2 @699/2200/1430Mhz
A SSD and some HDD's with DVD burner and reader...
After reading the Phenom II Guid, i have got my system running @
3.75Ghz (250x15)
x4 HTL for 1000Mhz
x8 CPU-NB 2000Mhz
as recommended in the Guid!
my RAM is clocked to std 1333 by a devorce of 1:2:66 i beleave it was.
Now i put the CPU voltage to 1.426 and the NB voltage to 1.202!
When i had it clocked to 3.75Ghz i used 3dMark06 as a small stresstest. First everything went oke, but then when it came to the CPU stresstest part, my computer Turnd OFF. BOOM
I have a Zalmann Cooler what is not that big but its bether then a StockCooler. Temprature was about so 55C
Can you tell me pls, what for voltage maybe i bether should use and wich Cooler i need.
It boots etc can surf, join TeamSpeak etc but when cpu power realy is needed, my system turns off, as it seems in the stresstest von 3dMark06.
After letting it cool down, i tryed to play a game (CoD:BO) and played about 10minutes, then shutdown.
So i guess i dont have the right cooler pls give me your advice.
Best Regards,
Fry
i have a :
3.75Ghz (250x15)
x4 HTL for 1000Mhz
x8 CPU-NB 2000Mhz
Best Regards,
Fry
