- Oct 6, 2005
- Fayetteville N.C.
wow 33hrs PRIME stable... Man did you actually sleep for 33 hrs??????LMAO great overclock man. I bet you can get alot more if that chip was on water!!!!
You know somethin' funny though guys...
The ONLY apparent problem with these settings, is EVERY time I turn the computer on (from being OFF, not resetting/rebooting with the power on), it will come on for about two seconds then turn off, and stay off for about two seconds, then turn back on. It doesn't actually POST until the second time it comes on, but it does stay on the second time, and proceeds to load the OS.
I was curious as to why it was doing that, so I went into the BIOS and tried upping some of the voltages, all EXCEPT the vCore. 5 or 6 modifications later, it's still doing it. So, I set literally ALL the voltages to auto, and bumped the vCore to 1.35000 to see what would happen. Voila...it stays on the first time I turn it on, POSTS, and proceeds to load Vista no problem.
But, I'm not about to increase the vCore higher just to make the BIOS happy for a cold boot. Like I said, at 1.31250 vCore, it is 33 hours prime stable. The only problem is what I just described. I'll take that though, gladly. Since I run my system 24/7, I want the lowest "stable" vCore, and more than 33 consistent hours of Prime95 is enough to convince me, not this silly cold boot nonsense.
Anybody have any thoughts on that though?
