"(6) Do I need to run 1:1 memory to achieve peak performance on the Athlon 64?
Not really, given the Athlon 64 architecture and the integrated memory controller, there is no statistically significant advantage to running memory at a 200 setting versus a 166 setting at, for example, around DDR400 speeds. Even at the 200 setting the memory in an Athlon 64 system is running async. The memory speed is arrived at by using a divisor off the Athlon 64 CPU speed (i.e. a /12 divisor.) Also, unlike the Pentium 4, the Athlon 64 is not bandwidth starved; thus, the difference in memory speeds between DDR400 and DDR 500 is at most 1-2%. In other words, don't go crazy and throw away perfectly good PC3200 RAM thinking you'll see a significant boost using DDR500 for example; you won't, and your wallet will hurt."
Does that mean my RAM (PC4000) will be entirely superfluous compared to my PC3200 BH6?
Also, is 15x200 the same as 10x300 on an athlon 64?
