Opteron 144 @ 3.1ghz... Believe it or not *PICS*
Hey guys,
PICS--Recently restarted due to changing ram timings but was Prime stable last night for 8 hours at these CPU settings. The Super PI score for 32M shown was at these settings with less than optimal memory =)
I purchased some Opty 144's recently,
First one from the batch is a CAB2E with I think a GPAW 0602 code.
I'm using a DFI Ultra-D -> SLI
Thermaltake Venus 7700 cooler thing, its just a copper version of the OEM cooler.
High end aircooling in my case but nothing excessive.
480-W Antec Neo.
Currently priming 344x9 = 3100MHZ. No errors yet. 1.55v
Was stable at 333x9 = 3000MHZ at 1.45v.
**I'm thinking this has just about maxed out my DFI Ultra-D**
Load temp 48C.
Wonder chip! Thought I'd let ya'll know these newer CAB2Es might be quite good.
***UPDATED***
Posted 350x9 in windows. Erorred 30 minutes later.
Posted 350x7 to test the motherboard, erorred same time.
Tried bumping the voltages on the motherboard no luck to increase max HTT. Guess I maxed out this DFI Ultra D. Any other NFORCE4s go higher?
@3.1 344x9....
Still running prime... No errors. 46C now lol.
I'm using a 1/2 divider because I didn't want to have any memory problems.
But they are 2x512 OCZ @ 2-3-2-5 normally at 210fsb.
I have a few more of these chips to test hope they all do as well.
DFI Ultra-D -> SLI Mod
2x BFG 6600 128MB @ 500/600 passively cooled
WD 120GB ATA133
52x24x52 LITE-ON CDRW
Antec Neo Power 480W
2x512 PC3200 OCZ @ 2-3-2-5 210FSB @ 2.7v
Stock motherboard voltages
3x 120MM fans
3x 80MM fans
Antec SX1030 I believe it was Case.
5100 3DMARK 05 right now =)
Hey guys,
480-W Antec Neo.
Load temp 48C.
***UPDATED***
@3.1 344x9....
WD 120GB ATA133
3x 120MM fans
3x 80MM fans
