- Dec 14, 2010
I thought I would try overclocking an E8400 C0 stepping C2D I had here to see what it could do.
Step 1. Find the lower voltage limit of its stability.
So far I've got it to run at 1.14-1.17V (after Vdrop and Vdroop) and it is Prime95 stable, down from the stock 1.25V. Had it running at this setting for around 5 hours now with no noticeable issues. Temperatures seem to be the same as at the stock voltage, which is odd considering I was expecting at least a little drop in temperature; I did see a slight temperature drop when I did this on one or two of my AMD CPU's as well as my Intel E4400 C2D and figured I would see a similar change here.
Step 2. Seeing how much voltage it takes to run at say 3.5 or 4GHz, or if it will run at those speeds at all.
Step 3. Finding a good 24/7 overclock that is stable and doesn't run too much hotter than stock.
CPU in question has a VID of 1.25V, date code is Q825.
Stock (3GHz 333x9): 1.1v (1.13125v)-EP45-UD3P
3.1GHz: 1.1v (1.13125v)-EP45-UD3P
3.2GHz: 1.12v (1.15v)-EP45-UD3P
3.3GHz: 1.17v (1.18750v)-EP45-UD3P
3.4GHz: 1.18v (1.21250v)-EP45-UD3P
3.5GHz: 1.22-1.23v (1.25v)-EP45-UD3P
3.6GHz: 1.25v (1.2750v)-EP45-UD3P
3.7GHz: 1.296-1.32V (1.35V)-EVGA 780i SLI
3.8GHz: 1.336-1.376v (1.40v)-EVGA 780i SLI
3.9GHz: 1.368-1.408v (1.43750v)-EVGA 780i SLI
4GHz: 1.408-1.448v (1.4675v)*-EVGA 780i SLI
Intel Core 2 Duo E8400 C0 #2 overclock settings
VID: 1.225v
Stock (3GHz 333MHzx9): 1.104v (1.125v)
3.2GHz (356x9): 1.152v (1.175v)-47°C
3.3GHz (367x9): 1.168-1.184v (1.20v)-49°C
3.4GHz (378x9): 1.20v (1.225v)-51°C
3.5GHz (389x9): 1.248v (1.275v)-51°C
3.6GHz (400x9): 1.280v (1.3v)-54°C
3.7GHz (412x9): 1.328v (1.35v)-55°C
3.8GHz (423x9): 1.344v (1.375v)-55°C
3.9GHz (434x9): 1.376v (1.4v)-58°C
4GHz (445x9): 1.392-1.408v (1.425v)-58°C
4.1GHz: Not happening at any settings
VID: 1.225v
