Hello Overclockers,
This is my first post because I'm having trouble with my rig.
I'll try and describe as good as possible the problem.
1) System specs:
CPU: Intel Core 2 Quad QX9650
CPU Cooler: Thermalright 120 Ultra Black + 72mm fan
Motherboard: Asus P5Q Pro
RAM: Corsair 4 GB DDR2 800 Mhz (TWIN2X4096-6500C5) (2 sticks running in dual channel)
Case: Antec 300 with 2 intake fans, 1 big outtake fan and 1 back fan.
Power supply: Corsair TX-750 (750 Watt)
Videocard: EVGA GTX285 Superclocked 1 GB
Bootdrive: WD Raptor 74 GB
Storage drives: Seagate 300 GB, WD Black 750 GB, WD Black 1 TB
DVD-RW: Plextor PX-760
DVD-ROM: Plextor PX-130
Speakers: Cambridge Fourpoint Surround System
Keyboard: Logitech G11
Mouse: Logitech G7 Cordless
Monitor: Iiyama Prolite E2607WS
OS: Windows 7 Ultimate 64-bit (Dutch)
2) Problem
I have build this system mainly for gaming. I just want my games to play smooth and fast. So I decided to OC my CPU. Also because this OC won't bottleneck my GTX285.
When I play with my OC settings my games crash during gameplay.
It mostly happens after 1 hour or more. Games I play now are Dragon Age and Mass Effect 1. I even can let it crash in Windows 7.
I think it crashes when I hit my tower (not on purpose, but my tower is placed underneath my desktop. It is placed on a holder so it does not touch the ground. The holder sometimes shakes when I'm gaming (and mostly then my PC freezes)
But I don't think this is the problem. I already checked cables.
Strangly it does not happen on stock, not even when I knock on my tower.
I tried but I couldn't recreate the problem. I'll try even more to ensure this is not the case.
UPDATE: The problem indeed happens even when all settings are back to stock. So I guess my OC is not the problem.
Now I hear you saying your OC is not stable. Well I thought it also until I stressed my PC.
Prime95 Blend test: Stable for 12 hours!
OCCT Large Data Pack: 7 hours stable!
Memtest: 4 hours with no errors!
I can do a Prime95 small FFT test to ensure my CPU is stable.
I'll let you know what the outcome is.
3) My OC settings
CPU Ratio Setting = 10.0
FSB Frequency = 380
PCIE Frequency = 100
FSB Strap to North Bridge = 333
DRAM Frequency = DDR2-761 Mhz
DRAM Timing Control = Auto
DRAM Static Read Control = Enabled
DRAM Read Training = Disabled
MEM OC Charger = Disabled
Ai Clock Twister = Auto
Ai Transaction Booster = Auto
CPU Voltage = 1.35v
CPU GTL Reference = Auto
CPU PPL Voltage = 1.54v
FSB Termination Voltage = 1.28v
DRAM Voltage = 1.90v
NB Voltage = 1.32v
SB Voltage = 1.20v
PCIE Sata Voltage = 1.50v
Load Line Calibration = Enabled
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
CPU Clock Skew = Auto
NB Clock Skew = Auto
CPU Margin Enhancement = Optimized
4) What I already tried
I tried different drivers of nvidia but the problem stays.
I check my power cable and I even replaced it with another.
If anyone could send me in the right direction to fix this problem, I will be very grateful.
Thank you very much in advance.
1) System specs:
2) Problem
3) My OC settings
FSB Frequency = 380
CPU Voltage = 1.35v
NB Voltage = 1.32v
SB Voltage = 1.20v
