- Apr 1, 2002
Hi all,
Wondering about the possibilities of the prometeia system as a silent computer solution.
My question to owners of such vapor change cooling owners is:
if you don't plan to agressive overclock your cpu, could you set the prometeia system up to:
a) start up faster (4 min is long for me) by changing the start up temp to be > 0 degrees celcius.
b) stay at temp around 0-10 degrees celcius instead of sub zero by reducing the speed of the fans...
The result should be a computer that starts up within 2 minutes (time from power on to post) and cool enough to overclock some (man, 10 degrees celcius is way enough compared to ambient temps from watercooling)
