I'm running a rig with a Q6600, Asus P5K-E and Corsair memory. I can't get stable above 3.645 mHz (FSB 405) Prime stable. I can boot into Windows with at least 3.8, and it will POST, but go into an endless loop of starting Windows and rebooting on 4.0 gHz. I have tried reducing the multiplier and increasing the FSB, and I have no problems going to FSB 480 with memory 1:1 on multiplier 6, so it's not the motherboard or the memory.
I thought I should be able to get further with water cooling. I'm starting to wonder if this is because of the ThermalTake BigWater waterblock. I have two radiators running on this thing, and 1,5 VCore (this computer isn't on 24/7, it's a HDPC and runs for a couple of hours 2-4 times a week.
The reason I suspect that the water block is holding me back is that Prime95 gets the temperature in Core Temp up to well over 60 C, and it can get up to 70 at times. But when I stop Prime95, it falls by 20 degrees within 2-3 seconds. That seems to fast for me, I would have thought it should take at least 10-15 seconds. Or am I totally off here?
This is a G0 from an early batch of those, btw. VID is 1.2750 in Core Temp.
