- Jul 15, 2004
- Loma Linda, CA
Wondering how tight you compress the springs when mounting this block... Anyone have a picture of theirs I could take a look at?
Reason I'm asking is I'm gettin mid-high 40's in temp under normal use with the following hardware/cooling:
AMD Barton 2500+ @ 3200+, 1.8v
Radeon 9800Pro
Asus A7N8X-D
WW Block
Swiftech GPU Block
Danner Mag 3
Cylinder Reservoir
86 Chevette HC (Dual 120x38mm Y.S. Tech fans push/pull)
Seems a little high to me...other systems on air are runnin approx the same temps w/ the same overclock, so gonna remount my water block first off, just want to make sure its done right...
thanks.
Radeon 9800Pro
Asus A7N8X-D
WW Block
Swiftech GPU Block
Danner Mag 3
Cylinder Reservoir
thanks.
