Hi guys
I've a Quick question about Games requiring 3 or 4 cores
More and more games are requiring multicore processor, such as GTA and BattleField Bad Company 2
I was wondering.. if a core i5-650 has dual core only, but can run 4 threads using hyper threading, and using software you can see that it seems to be really quadcore (separate processing etc)... will it then be accepted by the games as QUADCORE? I mean will the 4 thread processing be same to the multicore requirement of 4 cores , in Game requirement terms so to speak..
Coz im trying to recommend a gaming PC for a client w/ a limitted budget and the core i5-650 is the primary choice w/ only 2 physical cores, but 4 threads via HT..
http://ark.intel.com/Compare.aspx?ids=42915,43546,
regards
TJ
regards
TJ
