- Jul 29, 2001
Hey guys. I decided that I want to build myself a Smoothwall rig to have a real router with expansion possibilities for my line upgrade (8M/800K), and so I did.
The parts are used were stuff I had laying around unused:
CPU: P3-933MHz ES, unlocked rev B0 Slot1 CPU clocked at 400MHz (133x3), cooled by a large passive heatsink.
RAM: 192MB PC100/133 SDRAM (3x64MB)
GPU: Matrox G200 or something really old.
NIC: Realtek RTL8139 NICs (1 to modem, 1 to LAN)
Mobo: MSI MS-6163 mobo
PSU: Generic POS 300W.
And a Western Digital 4.3GB hard drive
Now the CPU has a huge passive heatsink and is clocked down to 3x133MHz for an effective 400MHz, so there's no noise problem there.
But this hard drive is making a high pitched whine that is audible and it chugs like a tractor.
As this project is supposed to be a $0.00 type of project I am now looking for ways to quiet this thing down. I'm not shooting for complete silence, but I'd like to take the noise level down a few notches if possible.
The Smoothwall is built into a pretty old Midi-ATX case.
I would appreciate any suggestions you could give me about different ways of quieting an HD down with things you can find at home or real cheap stuff you can get in stores. This does not have to be pretty, just quiet.
Also airflow should be a consideration.
Thanks in advance.
Thanks in advance.
