I don't want to discourage anyone from testing and I'm open to hearing the results, but let me be the first to call bull*** on the principle. Unless there is some truly novel physics involved radiative emissions at the temperatures we're working at are so small they can be disregarded completely.
For example, everything that has a temperature above absolute zero emits some IR, different materials emmit different amounts at the same temperature, but the absolute physical limit is a so called "ideal blackbody radiation" and there is a formula for it that depend on the area and temperature. So let's take 70C as our temperature (343K) and an area of an imaginary ihs of 4cm square. Plugging our numbers into the blackbody radiation formula we get 785W for a square meter of area or 0.314W for the area of our Ihs. This is a 100% negligible amount of radiation energy.
Now, one can imagine an obvious approach to increase this by increasing the surface area by introducing lots of tiny nanoparticles suspended in a medium transparent to IR. But then once each of these nanoparticles cool down themselves how is more thermal energy supplied from the ihs to them? Via normal conduction which makes the radiative part of the thing irrelevant. This is before we even get to IR transparent cold plates.
However, perhaps there is some new physics involved. One should always keep an open mind with such things(no sarcasm, really) . For example no one a hundred years ago could imagine you could transmit a library of Congress worth of data in a second over radio waves. They would've called it impossible.
But, if there is new physics involved, why are you making consumer coolers with it rather than satellite/space cooling tech?
One of the biggest limitations in space engineering is that all cooling in space is radiative(unless you're willing to loose mass). For example the international space station has radiators area as large as its solar panels to be able to cool people onboard and not let them slow cook in their own body heat. Likewise with many (especially RTG powered military) satellites. That's where money is if you have a revolutionary radiative cooling tech...
