After doing some enhancing to my machine , finally I am alive&back again!
@ joikd:
Do not worry; that slotket I found by yesterday experiments IMHO the Best !!!! (even if has no damn large chip on board)
Today I pushed my Tuallie on SuperSlotket3 ver.1.0-noname Taiwaneese made with no "big" chip on board-generic one /with a bit different mod-posted here by Sammy/ from 1.0A to 1,55G with PC100 Cas2 64Mb ram with 1,85 Vcore /shows 1,8/ on 235W !!! Enlight PSU. I made some benchmarks on 1,5G (still NO data corruption!): It really kicks *** to P4wiliamettes !
Would kick *** even more to new expecting Williamette core Celerons!
It was a really cheap uppgrade to my machine to double performance @1,35GHz where I will keep it with 1,52Vcore not to bother spending twice such money & time additionally just to gain another 10-15% of performance buying a new PSU&ram & other stuff to make machine be LOUDER; now it is quite silent! When you pass 1G & 133fsb IMHO really doesn´t matter much except benchmarks or for special purposes; the real bottleneck is in fact HDisc access time, which slows the machine...
I also tested my setup @1,35 with a demo loop RallyMasters game with open case, but I forgot to put the fan on heatsink!!! After realised that (3 hours later!), the game was still running smoothly... LOL (yeah, the heatsink was hot!) ! If it would be AMD Duron would be dead instead & fire in the house..! It was a REAL Burnin-in..
! I have a Philipphiness SL5VP, 1st week March OEM retail chip!
@ ALL: /Thanks to Sammy for info for that mod on SuperSlotket-III ver.1.0/
With my yesterdays experiments /damaged also plastic Slotket holders a bit!/ I found interesting facts that may stabilise your CPU @ higher frequencies: instead of ak4-ak26 bridge /w or no resistor/ I used instead direct hair thin wire bridge on s370 between isolated AK4 & non isolated AN11 (Vtt) pin !!! Advantages: the wire is shorter & bridge easyer to do & so recieving less RF noise to the CPU thus improving stability also because Vtt pin is RF decoupled to GND by capacitors, while ak26 has much higher impedance & not decoupled! So also VttPwrGd is now RF decoupled too & Cpu more stable !!! Also now is no need for safety serial resistor in bridge against higher voltage because on Vtt is fixed on 1,5V needed for VttPwrGd, whatever the Vcore is !! You should TRY this manipulation leaving the ak26 pin alone!
